Re: 351 marine conversion
Kk,
My $.02
I don't want to smash any dreams or discourage anyone from pursuing their interest...but I must ask, what's your end goal? To have a slightly faster boat? Replace the engine? Or?
The reason I'm asking is looking strictly from a dollar and a brain damage standpoint, it'll be far easier to buy a long block 302 (complete with new intake manifold, heads, oil pan, valve covers, etc...) than to locate a 351w, convert what needs converting and then address new parts in the future. I get the feeling your knowledge base is not currently at par with what it takes to do the swap you're contemplating. I don't say that too be arse, but from a logical standpoint...302's are more common than a 351w (moot point), the swap would be a direct bolt-in, in the end it'll be closer to what came with the boat originally, so resale will be easier to consummate. In the end it'll be substantially more cost effective to replace/upgrade a 302. You could also upgrade cams, intake, carburetor for more performance?!
If you choose to do the swap, you've got the right guys on board, as they'll get you where you want to go. They can help you spend you money wisely or unwisely, whichever way you decide.
I went through the same process mentally and decided (for monetary, mental sanity and expediency) to just replace the 302 in my CC. I was able to re-use all the original marine parts (heads, intake, exhaust, belt, pulleys, pumps, covers, dipstick, etc...). There was very little brain damage (all the existing is still intact) and to the common man (or woman) the motor install is (and looks) factory. I can replace the exact part with one from the original motor.
Good Luck.
~Brett
P.S. the Ford 351/400M were junk...low torque and low HP...what a great combo for a heavy truck!!! Very few mods available...I had a 1978 Bronco with the 400M, ran reliably, but not exactly a stump puller.
