haulnazz15
- Joined
- Mar 9, 2009
- 3,720
Re: 302 marine conversion
The heads have apparently been replaced at some point. Those are GT40 (non-P) heads, common on most 90's trucks/SUV's. They are a good match for a boat because they are normally good for torque. For what you're doing, the heads are perfectly fine as compared to the stock 302 heads. Did you ever check the S/N on the engine block? You might have a modern-302 in there that replaced the original 302. In that case, all the better. There's not much difference aside from firing order (351-style) and a one-piece rear main seal (better).
