netting one
- Joined
- Mar 23, 2010
- 112
Hi guys, it took me a week to try to read all the back logs on cracked blocks,cracked heads, blown head gaskets. Well here is my problem. My buddy took his boat out for the first time since his grandpa passed. (only 134 hrs on boat and out drive) we had it out with me and it was doing great, then the out drive broke the top gears(low on oil) then he ran the engine until it got hot into the red zone. When he brought it to my shop i went to turn it over and the cylinders had all 6 full of water!! At first we were just holding the key to try to get it to turn over. (not good) so here is my guestion, how did water get into pan? and its clean about a 1/2 gal ihad the heads in the shop no cracks, the intake manifold did not leak into the valley,the block around the cam shaft is good,the cylinders look ok after ball honed and checked. can water go by the rings? my engine guys say no, how about under turning the key? also it is not milky at all also. well thats it! right? thanks guys
