If I can get it to stay running the IAC will go over 100. Check the data files I emailed you with the good and bad engine.Just comparing to my 7.4 LX data files. . . wondering about the IAC position . . . looks high on your engine.
Comparing the data files of the good engine and the 'troublesome' engine may be helpful. Send them as you are able.
tried putting the cheap injectors in. still wont run. will try the iac right now.Did you try unplugging the iac? Missed if it's still running ok using cheap injectors?
Rigol has some decent ones for a pittance (relatively speaking). I recently picked up their entry-level DHO 4 channel scope, and I still have the older (but in some ways better) DS1054Z. There's no reason a decent o'scope should be thousands of dollars nowadays.I think it is time for me to invest in an oscilloscope. I want to compare the injector voltage and current waveforms on both engines to see if the injectors are actually opening as commanded by the ECM. Also hook it up to the ecm power and ground feeds and distributor rpm signal to see what is going on.
Yep. All based on existing GMECM tech from the 80s. Automotive ECUs have the advantage of a BLM table... having a closed loop working in their favor. So you take the base fuel table which is burned in a UVEPROM, monitor the INT(egrator) under normal driving conditions, and that creates a persistent (until it loses memory power at least) Block Learn Mode table which is basically a correction factor for the main fuel table.MEFI's all use fuel tables
The table simply is a X and Y column table.
rpm = A
Temp = B
MAP = C
injector pulse with = D
So I'm not sure. The MAP is initially appropriate, ~15. Then the IAC keeps opening and the MAP increases, which would indicate more air getting to the sensor via the IAC, throttle open, or leak. The injectors look to be responding appropriately to the MAP and RPMs. If this was unmetered air the MAP wouldn't show the increase. So I'm still thinking IAC open is causing a lean condition/stall.%.
I am thinking that the 'bad' engine is being air-starved. . . not sure how, but I'd be checking the throttle body and in particular the air bypass.
I'm just looking at post #73. Good engine has initial drop/snap back as engine first fires and settles at 21. This is still higher than I'd think it should be (would be only 11 mmhg vacuum). Bad engine has initial drop, but no snap back, it returns gradually to 26, so only 4 mmhg vacuum at that point. Healthy engine at idle should be > 18.It looks like the initial barometric pressure (Baro MAP) is 30 and the 'good' engine goes down to about 12. The 'bad' engine goes to about 8.5. It also looks like the 'bad' engine was able to keep running if/when the IAC moved all the way up to the 155 range, and so the injector pulse stayed up in the 3.5 ms range.
On the runs that the engine stalled, the IAC position only got up to 100 and the injector pulse stayed below 2 ms.
On the tests where the engine continued to run, it appears that more air was let in via the IAC and the MAP was maintained at around 21.
