Silvertip
Honorary Supreme Mariner
- Joined
- Sep 22, 2003
- 28,772
Re: 4cyl vs. 3cl vs. 2cyl?
Actually it is not the bore of a cylinder that provides torque, it's the stroke. Remember, an engine uses a crankshaft to convert up and down motion into rotary motion. That crankshaft has rod journals that form a lever. A longer stroke is equal to a longer lever. High torque motors like truck engines tend to have long stroke compared to auto engines that tend to favor large bore short stroke which provides high reving capability even though the displacement may be the same. Long stroke truck engines are not very high reving, nor would you want them to be. Hence you have under-square and over-square engines. How the manufacturer of those engines manages the torque, horsepower and resulting fuel consumption curves depends on what type of service the engine is intended for. One need only look at the various versions of the venerable Chevy small block to see the relationship between bore and stroke. The same block has provided 262, 265, 283, 302, 305, 307, 327, and 350 cubic inches. And in the process there have been a gazillion different torque and HP ratings. Note the similarity of the 302/305/307 but the bore and strokes on those three engines were quite different because those engines appeared at very different times and with very different needs.
