Rolf Latham
Thread starter- Joined
- Jan 10, 2008
- 11
Hi All
First post in desperation
I have a Bayliner 2355 Ciera, fitted with the Original 5.0 Carb 230 hp engine, raw water cooled, running Alpha 1 drive and a 17 prop
Purchased the boat about 7 mths ago, 1996 model in good condition overall.
Just previous to purchase fitted with new manifolds and risers, passed its pre purchase inspection test all fine, good compression, easy start, great running etc .
About 30 hrs use later cracked a head, ok no big deal, tow it home, empty the engine, fit a new head, check out cooling etc all good. Running great again.
5 hrs later ..................crack the other bank's head.
Both Heads had shown signs of valve seat recession and a bit of corrosion, I assume from the old manifolds which may have leaked a little.
Replace the second head with a new one, while out of the water, do the sterndrive impeller, leg service, do the thermostat and general cooling check etc .
Ruuning fine, stronger than ever ..........and very happy .............for an hours running time
Suddenly.....low power, will just get on the plane, though revving ok, with occasional misfire, one manifold running cool to touch, other side noticeabily MUCH hotter.
In addition, temp guage is showing slow flucuations of from 100 to 175 degrees on plane...................
Pulled leg and cooling system to bits, replaced missing shutters, no obvious blockages, compression good, no water in the oil etc
Timing is ok, new leads, new plugs, both barrels on the carby ok, fuel is fresh.
Starts easy, runs at 2000 rpm clean and ok temp, as soon as asked to load up she doesnt want to move to much............
My mechanic and I are both at wits end.
Im close to spending the money on a 4.3 MPI re power, and tossing the old engine out as a boat anchor............BUT just before making that big commitment I thought, hey ask someone else
Ideas please ?
ta
rolf
Ideas please ?
ta
rolf
