6 hp evinrude outboard help please
phrozin
6 hp evinrude
1968
model 6802C
not getting spark on 1 lead and getting barely any spark on the other
should i replace the coil pack or the leads or the condenser?
dont know where to start checking why im not getting good if any spark
phrozin
Re: 6 hp evinrude outboard help please
ok.. i dont get it.. it not even wanting to turn over at all..
carb has gas, checked out the ignition, reset the points, have good continuity all the way to the plug.. just not wanting to attempt to turn over.. not even getting a sputter.. im lost..
phrozin
maybe the timming is off?
Cap'n Chaos
Timing is set by the points.
Have you checked compression yet?
Have you rechecked spark after resetting the points (with an air gap tester) ?
What is your starting procedure - are you turning the throttle to "start"?
phrozin
are the point supposed to touch? if not how do i gap em.. i read .020" somewhere.. is that right?
nwcove
points have to touch, and be clean, gapped to .020 at their widest open spot. ( look in the "top secret file " at the beginning of this forum)
phrozin
i see where the breaker cam is supposed to touch the center spinal.. but the breaker points are supposed to be gaped?.. wish there was a video on this.. im not the type to read and comprehend well.. i need to see it done to do it..
SeaKaye12
The points "touch" until the rubbing block is pushed by the high-point on the cam (crankshaft). That's where you set the gap with the feeler gauge.
So; they are closed (touching) except for that brief interval where they are forced open by the cam.
Chuck
phrozin
is this what you mean seakaye12?
MercMan82
the other end of the rocker is where the point is.your arrow is where the rocker rubs against the crankshaft. as the high spot on the crankshaft comes around the rocker arm is pushed and the other end with the contact backs off and makes a gap. see in the diagram "breaker points"
phrozin
so the breaker points only touch when its at the high spot? and should be gaped .020 otherwise? should the rocker be rubbing the crankshaft at all times then too?
MercMan82
your main objective is that you set your point gap(using the adjustment screw) and that it touches at the right time because as soon as it touches, it will send a spark to the spark plug. that is simplified timing.
SeaKaye12
PHROZIN....
You don't indicate where you live. Tell us and maybe one of us can stop by and take a look....
Chuck
nwcove
maybe im reading this wrong, but the points should be always closed until they get opened by the lobe on the points cam, ( usually where the keyway is located), thats where they should be gapped to .020. ( !!!plugs only fire when the points are open!!)
