simplystressed
- Joined
- Mar 16, 2009
- 176
I have a 6hp 4 stroke mrcury and I notice it really vibrates on my boat at all speeds (worse at higher speeds it seems). Its too the point where it shakes the whole boat and my hand is numb from holding the tiller. Afterwards noticed one of the bolts was loose down by the release mechanism (1 of 4 that hold the casing together). Tightened that up and haven't tried it since not sure if that would help that much.
Boat is an 16' aluminum about 1300lbs. Pushes it to hull speed but needs to be at WOT to do so (around 5.8mph). Its fairly noisy but the vibration is the biggest concern.
Is there anything else to tighten on them (bushings etc) that will help? Maybe getting a different prop? Haven't measured rpm's at WOT yet though but saw other threads about a high thrust prop. Not sure if that would help with a 1300lb boat. Going to an 8hp would add lots of weight, so hoping I can improve this issue.
thanks in advance!
thanks in advance!
