6HP Johnson shift lever change help
HantsCounty
Hey guys,
trying to change the lever on my gear shift, got the new parts but cannot figure out how to get the bottom part of the outboard so I can disconnect the rod so I can pull the rod up to switch the lever. I was told by the local Johnson BRP reps that I need to take the bottom off the outboard to disconnect the rod so I can pull it up to change the lever. Is this correct?
I have attached some pictures, one showing the lever on the rod with the powerhead off. The other is how far I can get the bottom dropped down.
Thank you in advance, and I did try to search but with the lack of knowledge of outboards I do not know the correct names of the parts to search.
bonzoscott
Re: 6HP Johnson shift lever change help
I'm not sure about everything that happened and your description, but in the first pic: when you separate the lower unit with the drive in reverse, you should be able to see a 3/8 nut on a coupler in there. Loosen that up and your shift linkage will come apart allowing you to drop the lower unit. It's a bit tricky getting it BACK together.
Rick.
Just bought my first 6HP Evinrude. A 1968, but I haven't done a thing to it and I am not much help to you except to share a site that may well have the answer to your question. Look down nearer to the bottom. Best of luck. Rick.
http://www.leeroysramblings.com/
boobie
Got a model # ???
HantsCounty
I don't remember doing one of those, but can't you just remove #25 and remove the shifter handle?
http://www.ishopmarine.com/ishop/js...nown&isFrPG=false&forItemCode=&pCode=C0092672
#25 is what. Broke, I am trying to pull up #65 to change it.
So bonzoscott The shift linkage is what's is keeping this from dropping down? I do see the coupler in there, tried to use the slotted screw driver to get out but won't move. I will try and get a socket in there.
