SkidRowBill
- Joined
- Jun 8, 2015
- 295
Petty Officer... does that mean that I have to complain about every little thing???
[/URL Once installed I want to use the silicon II because the silicon on the old transom did a good job keeping the transom wood dry... Please... any thoughts... Comments... boat jokes... I hope that the lightning does not hit the house again... althou its raining hard enough to put the fire out... Okay... Its back to the grind... my weekend is Tuesday afternoon and Wensday this week... I hope to get this wood done.... all my best... Just a dumb farmer from Maine... PS... to WaterMan... I told the Admiral what you said to tell her... it nearly got me the Yard Arm... she gave me three choises.. hanged from the Yard Arm... a stroll of the plank... or a week in the brigg without grogg... when I mentioned Yukon Golds she went off like a howitser... its the couch for me... this stems from the fact that we eat Maine grown Russetts here ... thanks for the advice...Roger That... my thoughts axactly... Althou I want to cut the two pieces first, glue and clamp them together... where am I going wrong and why... what should I do???
Hi Bill. We all do things differently. I don't see anything wrong. I would not depend upon simply clamping the wood together after gluing. I think the heavy angle iron is an excellent idea as a first step while the glue is still moist, but I would follow up with ss woodscrews spaced every 6" or so in all directions. Before screwing, eyeball the 2 angle irons for parallel to ensure that the assembly has no twist in it that will make life difficult later. Apply pressure to correct any twist using C clamps and blocks to pull the errant ends into alignment. I would orient the new transom such that the heads of the screws are all facing forward (inside the boat), rather than against the aluminum skin where trapped moisture could over time cause corrosion of the skin. - Grandadwhere am I going wrong and why... what should I do???
Hi Bill. We all do things differently. I don't see anything wrong. I would not depend upon simply clamping the wood together after gluing. I think the heavy angle iron is an excellent idea as a first step while the glue is still moist, but I would follow up with ss woodscrews spaced every 6" or so, starting from the middle and in all directions. Before screwing, eyeball the 2 angle irons for parallel to ensure that the assembly has no twist in it that will make life difficult later. Apply pressure to correct any twist using C clamps and blocks to pull the errant ends into alignment. I would orient the new transom such that the heads of the screws are all facing forward (inside the boat), rather than against the aluminum skin where trapped moisture could over time cause corrosion of the skin. - Grandad
can anyone tell me if the transom(top) cover EOM goes under the gunwale caps... mine just went to them and was plastered with silicon...
