'82 140 mercruiser- milky oil
140bb
I know it's one of three causes, intake manifold, head, or block cracked but what is the best way to determine where the problem lies?
Thanks for the help !
BLinindoll
Re: '82 140 mercruiser- milky oil
Personally, if I owned an 82 and had milky oil, I would say it's time for a rebuild. Pull it apart, have everything magnafluxed and checked to specs, put it back together. It might not be totally necessary, but that's just what I would do a this point. Then again, I do most of the work myself aside from the machining. GL.
ziggy
i had water in my oil shortly after i got my 75' nineteen. was the manifold. replaced that and the riser and ain't looked back yet...... compression still the same as it was prior to the incident...... i did get hip that i had an issue right away. and got right onto the repair. maybe a day or three between the time of discovery and being done with the repair...
140bb
we,ve only had the boat for a short while ,in the water maybe four times,
this problem first started when we went to go out for a ride,put the boat in the water and it would not crank . this was odd because i just ran it on muffs at home to make sure everything was ok. took it back home and pulled the plugs and found water in #3 cylinder( squirted out when i cranked it). i pulled the manifold and it did not look like it was bad(not really sure) . pulled the head off and gasket did look like it had a blown spot around the bad cylinder.
the cylinder does have score down one side of it. so i replaced gasket , torqued head back down, new gasket on manifold, oil change and started it up again. still getting water in new oil ,ran about 15 min and oil is milky again.
i could repace manifold and eliminate that for just over $200.
not sure how to proceed with this?
chiefalen
You pulled manifold and riser and they are original?
140bb
not sure?
manifold has BAR MARINE on the side.
they look like they have a few years on them, like the engine!
ziggy
on my L6. i confirmed a bad manifold by removing it. then filling up the waterjacket while on the bench. then left it overnight. next morning. the waterjacket was empty. the exhust runner was full....
140bb
i tried that the first time i had the manifold off, but only let it sit full of water for a few minutes. no water seeping into exaust or intake ports. maybe i was a little to hasty and should hae let it sit longer.i'll try it again (overnight) to see what happens before i buy a new one.
thanks for the tip.
