Re: '84-26' Starcraft Islander tear down and restoration
Lots of foam has been removed, the best way I found removing it was carefully using a sawsall with a long blade.
Getting ready to remove tank, lotsa fuel, lotsa siphoning. There are 2 small ribs that are rivetted to the main ribs on either side of the tank, they had to be removed to get the tank out. The pictures show the rib before and after being removed. I figure it's a 100 gallon tank and it half full. So it's imperitive the fuel is removed first. A hand pump was used with clear hose to draw the fuel down and installed an inline shut-off valve. Once the line was full, I then removed the hand pump and let the fuel flow into a gas container.
After using many of those small garbage bags, I finally broke down and purchased contractor size bags. The pic shows less than 10% of the foam that has been hauled out.
And yes the engine is coming out soon!
