urbanredneck
- Joined
- Mar 30, 2016
- 111
Hi folks,
First post here. Have been reading posts for a few weeks now, searching thru as much info as I can. Ill try and keep it short.
Just bought my first boat, an 87 Mirrocraft with a 40hp evinrude VRO, all original OMC hydraulic steering setup, etc...
Motor model number i believe is ECLUD 40hp.
Having some standard issues with not having much power at WOT as of late . Have had er out 3 times so far. Seemed to run fine at first. But last trip I decided to actually give it some gas, and i was barely moving, with random big power surges.
After research, i did the usual. Took off the air box and inspected carbs. Blasted some cleaner through them and drained the bowls. Some more engine-familiar friends said the carbs look super clean, so i haven't done full rebuilds yet. Plugs look fine. Fuel is new, all lines appear intact. Starts and idles just fine. What gives?
Also, have been told I should can the VRO and run premix. Iv read all the pros and cons. One thing i haven't gotten an opinion on is the ratio of oil being sent in at different temps.
Example, last weekend when i took the boat out, i got a low oil warning alarm. Plenty of oil, prime bulb was always solid. Then, after the fact i remembered it was 28 degrees. Would cold temps reduce the oil going in?
Most the folks who are against removing the VRO say its a reliable system and shouldn't be removed because premix doesn't properly lubricate at higher RPMs.
Im just kind of lost. Of course, im spending way more money then anticipated, so im looking for advice on where I should focus time and funds at troubleshooting my problems so I can get on the water.
I will update with more info as I remember it. Thank you all for your time.
