9.9 Mariner ignition issues
Bullie
An old family friend dropped off his little Mariner at the house today while I was at work. I have never worked on one of these so I appreciate all the advice I can get. I am not sure the year as I cannot get the serial number to pull up.
Compression is 112/110. I was told it had spark on the top cylinder but nothing on the bottom. It is true that you can see a spark if the plug is grounded to the block but there is no spark at all on my open air tester so I would say it has no spark on either cylinder. I did disconnect the kill switch before testing.
What should be my first move?
GA_Boater
Maybe reconnect the kill switch if you mean you just pulled the lanyard off, which kills spark.
Bullie
The stop button is what I disconnected. I tried it both connected and disconnected and only mentioned it in case someone suggested that it could be be a bad kill switch causing there to be no spark. There is no lanyard on this motor that I can see.
Bullie
flyingscott, I honestly don't know. I was hoping the serial number search would give me ideas but I came up with nothing. The serial number is lower than anything I see listed. It is a Yamaha made Mariner if that helps. I will go out and look for a cdi box.
Bullie
Telling the truth on myself, I assumed this motor was CDI until you asked me about it flyingscott. It does appear to be a points motor though so I can make a go with that. At least, I don't see a box. Thanks.
Bullie
Can someone point me to a parts breakdown on this one? I can't match the serial number with a parts list.
Mohawkmtrs
For your serial number, I get 1979 9.9hp
Serial Range (1979) 682-004461 to 682-011990.
