Re: '93 Sea Ray 200br Overhaul
At this point I noticed something very interesting with the PB. Something I think could be a good trick.
It was when I was placing the last layer of Mat over the bulkheads. As you can see on the previous pics, the small foam I added to increase the surface for the tank and sky locker covers was scratched and had some defects on them.
I also missed to smooth the rear inside corners of the tank hole, and I thought to finish them while layering the mat. So I prepared resin and PB.
Well, the fact is that I could dump the PB in any way on the corners, then put the mat over it and then with the roller I got a perfectly rounded shape. Way better than with a spoon, without sanding or having to work the mat
Then I picked some bits of PB and dropped them near the scratches. Yes, near, I even put them outside and without covering. Then I wet with resin and lay the mat and work it with the roller as usual.
The PB would move below the Mat until it managed to reach the holes and imperfections filling them, and leaving a smooth mat layer.
If there are no side effects, I think I'll use that technique on all the uneven surfaces.
I think that deserves a video. Perhaps I'll be making one, so you all can laugh at my inglis. :lol:
**Note that PB must be thick enough for not to dissolve when you cover with resin.
