- Joined
- Mar 8, 2009
- 42,612
So the drive wont experience any electrolisis or galvanic corrosion if the battery is taken out?
Never leave the boat in the water without a battery in the water, it needs to be their for the bilge pump.
The plug in I'm talking about is plug into shore power. You can still have some corrosion but not near as much as if is plugged in. The main issue is the B3 drive and the large amounts of stainless steel with the two props. The B1 doesn't have near the issue as a B3.
As for how fast you will go, IMO your going to easy hit 60 mph and probably a bit more. You have a 18 footer with an 5.7, it's going to move, be careful with it especially if you get much about 60, you could start to chin walk
