Lots of mis-information on compression in 2 strokes.----see post #23 and #38.
I did a compression test this morning, cold at 60 F, I'm getting 110,110,110,100,105 and 95. I'm picking another compression tester today, I have done some research, there was a comment about a crank case air leak. This is a possibility, other than disassembling the motor, can it be tested?
This motor did overheat, it's in my shop, my plan is to pull and do another rebuild, not matter what if done, its only running on 2 cylinders, I can cover the carb, my hand gets wet, but motor doesn't respond to the 4 dead cylinders,
