ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 955
this is sounding more and more like a piston mixup scenario. scary to think of what else was done! rod caps set properly?
I did a compression test this morning, cold at 60 F, I'm getting 110,110,110,100,105 and 95. I'm picking another compression tester today, I have done some research, there was a comment about a crank case air leak. This is a possibility, other than disassembling the motor, can it be tested?Lots of mis-information on compression in 2 strokes.----see post #23 and #38.
What happens if the pistons were not in the same cylinder? should I have bought new pistons? I know the rods are offset for clearance, on the crankshaft. I've had the motor running wot. its fine, it's the hard starting and running on 2 cylinders at idle.this is sounding more and more like a piston mixup scenario. scary to think of what else was done! rod caps set properly?
