SgtMaj
- Joined
- Nov 19, 2007
- 1,997
Well, since last year my a/c unit has been freezing up occasionally... this year it's noticably worse than usual. By freezing up I mean the return line (the large one) freezes solid and doesn't return the coolant, or so I presume, since the air coming out of the vents isn't cool when it does that. Anyway, last year we just turned it off for 15 minutes and then back on again and it was enough to temporarily "fix" the issue. This year it's been getting annoying doing that every day twice a day and the house get's HOT, like 80 degrees hot while waiting on restarting it... and it's not even all that hot outside yet, summer has just begun. Anyway, been fighting paying a pro to come out and fix it since I know it'll be at least a couple hundred bucks. I researched the problem and found that the most likely cause is a slow freon leak. Being the "smart" guy that you all have come to know me as...
...I figured that the unit couldn't use R12 since the house was build several years after R12 was banned. So being the "genius" that I am...
...I figured it most likely used R134a, just like vehicles do, since if that's the best freon for vehicle A/C's, then it must also be the best for home A/C units... so then I figured that being the "brilliant" guy that I am...
...I would just recharge it myself using the car recharge stuff which I use frequently on the jeep because it also has a leak and requires monthly recharges in order to stay cool in the summer, and I would just save the service call on the home a/c unit. Turns out... big surprise for you all I'm sure...
...that it has a slightly different connector than the vehicle A/C's have. So the net result was a slight further loss of freon from the home a/c unit which makes the problem even worse. I'm sure you're all shocked that I would do such a thing...
...so anyway, I figured I'd just go out and buy the right connectors to charge it and still save the service call. But it turns out that around here you apparantly have to be a liscensed HVAC person to get those connectors. DANG it! Now I'm going to have to hire someone to come out and refil it... and I'm sure they'll want to try to find and fix the leak... all of which will cost money I'm sure. Why the state won't give me of all people...
...a liscense just because I'm me, is beyond me. Surely they've heard of my other projects and can see I'm obviously qualified... lol (unable to use image again because I'm limited to posting 6 images per post).
In my defense, I have successfully fixed this a/c unit before... when the capacitor died a few years ago, I was able to successfuly diagnose and repair the problem myself, and thankfully I was able to buy a capacitor for it without being liscensed.
I realize I would only be "renting" the freon since I don't have the know-how or parts to fix the leak, but since R134a poses no serious environmental concerns, I still think I should be able to refil it myself. I don't think that spending $200+ to get it fixed right is better than spending $10 every 3 years to refil it myself.
