Adjusting Rockers 4.3
jdtower23
Trying to get the rockers adjusted on my '88 4.3 OMC....most of them threaded down close to where they were before(have a pic) but one rocker on the #5 cylinder won't thread down as far as the others.....it seems snug also...I've double checked it and it seems to be in the lifter.....that pushrod is up so I guess that valve is supposed to be open.....it's a TDC #1....
Is this normal? will I be able to adjust it better by turning the motor to a different spot?
Thanks
Coors
Re: Adjusting Rockers 4.3
Run a die down all the way on the rocker stud, then retry it
Don S
What method are you using for valve adjustment?
jdtower23
Adjusting them at #1 and #6 at TDC...what my manual says....I got the cylinders adjusted with #1 at TDC......now I tried turning the motor over by wrench one revolution....it turned ok little by little then stopped! Didn't get it all the way around....probably 50% to 75% of a revolution
I did have a couple of rockers too loose so the valves probably didnt open....
What can i do?
jdtower23
Anyone have an idea? I'm really worried what's causing this...please help
Don S
My guess, you were on #6 when you thought you were on #1.
Have you ever worked on an engine before owning this boat??????
jdtower23
You mean initially? Honestly, i've never done anything like this....I've worked on cars, but only simple bolt-on stuff.....
Don't know if this tells you anything but it appeared before I moved it that both valves on #1 were closed and the #3 piston's exhaust valve was open.....when i turned the motor a little #3 exhaust was suddenly a lot looser and #5 intake
Thanks
Coors
And ,as usual, I won't say anything about a factory manual...
jdtower23
I know, stupid.....well worth the $105 now.....
Anyone know what's stopping the motor? I won't be able to sleep tonight until i figure this out....
Coors
Wrong, is one turn on yours.
Put on #1 , use finger to feel the pressure, get the balancer to read 0
Exhaust @ 1,5.6
Intake @1,2,3
then turn balancer to;one revolution, to 0 again (this is # 6)
exhaust 2,3.4
intake 4,5,6
WAVENBYE2
Maybe this will help.
jdtower23
Coors,
What I don't get is when I initially set it to what I thought was TDC #1....I really wasn't sure....but I pulled the cap and it was pointing to the #1 locations....I moved the motor slightly while apart.....but put it right back.....
Can I turn the motor backwards like this?
Thanks a lot
Don S
Yea, I know what's stopping the engine from turning. The pistons are hitting the valves.
To strart with, back off all the rocker arm nuts till they are flush with the stud.
I don't even know if you if the valves will move at this point. But, after you do this, see if the engine will turn by hand without hitting something.
Coors
Hope you didn't try to start it, if not you are cool.
jdtower23
Coors,
Didn't even hook up the battery.....but I tried what Don said.....motor turned back a little....still wouldn't go forward and now it won't do a damn thing! I am so pissed at myself for this....is there anything else i can do other than taking it apart again?
Thanks for your advice
Coors
Coors,
Motor turned back
How?You do have the plugs out?
Don S
Did you get ALL the valves backed off?
jdtower23
Yes, all the nuts are flush with the top of the stud....
