MikDee
Banned
- Joined
- Jun 6, 2007
- 4,745
Re: Adjusting Rockers 4.3
After rereading your posts, I see you had the engine apart, all bets are off then! You now have to determine where TDC on your crankshaft is, as your cam is set to fire cylinder #1, then make sure your distributor lines up to fire #1 at the same time (you might have to remove your distributor, and reset it to do this). A hint here, both intake, & exhaust valves, should be closed at TDC for cyl.#1.
