Alpha one shift interrupt switch
gavincollison
Have a mercruiser 190 with alpha one is it absolutely necessary to have the shift interrupt switch fitted as I don't have one
ENSIGN
Re: Alpha one shift interrupt switch
You better get one.Without the switch working you won't be able to take the boat out of gear unless you shut the engine off.
Ayuh,... Without it, you won't be able to come outa gear, 'n it'll stretch the cable, Badly...
dubs283
you will hate docking your boat without one
cable stretch and skipping through nuetral are common occurences when the switch fails/is bypassed
the switch is there for a reason, if yours is broken you will have to repair the switch, they are nla from merc
Don S
While that switch is NLA from Mercruiser, they do make a replacement kit that uses the newer style shift interrupt kit.
The kit part number is 864363A1
gavincollison
Thank you all for your replies. I have the Base plate and all of the mechanical parts. This seems to be working fine. The only thing that is not fitted is the microswitch itself. Does anyone have a good part number for one of these and does anyone know where the cables should go?
gavincollison
As an alternative to tgetting a part number can some one tell me if this is just a basic microswitch. Pressuming that when switch is in the relaxed position it is open circuit, then perhaps when you go to change direction it grounds out something (coil maybe) so it would go closed circuit?
The reason I ask is that I used to work in an aircraft maintenance hangar (still have lots of friends there ;)) and i remember that on most aircraft doors they use a microswitch to sense when it locks. It looks spitting image of this imageswitch.gif
Mounting points maybe different but that can be modified. I shall see if i can aquire one.
Just need to know circuit diagram/information please?
achris
More fish than mountain goat
Many people have tried to replace the switch with a 'generic', all have failed. You need the kit Don told you...
Sandbank
From experience...the boat can be very dangerous without it as sometimes it may just not come out of gear. Not to mention the strain you are placing on the lower unit gears.
gavincollison
Ok To reassure you all I promise not to put the boat on water untill the microswitch is up and running. Everything I need is there so i'm not willing to pay ?100+ for a microswitch.
Guy's it's a microswitch, is there more to it than a simple switch mechanism? Does it have an internal resistor or diode? Has anyone metered one of these bad boy's to check for resistance?
I've read a couple of posts and people have wired them back to front and they wont work? So i'm guessing maybe a diode.
Has anyone taken one apart to look at the internal workings/components? Internal pictures?
This post could save alot of people with similar problems a bit of cash.
gavincollison
Fyi the switch grounds the negative connection of the distribution cap which prevents a spark.
Fishermark
You are correct - it is a simple switch. My concern would be longevity. Most switches do not last long in a salt water environment (or even fresh water) unless they were specifically designed to do so. Just sayin.....
find one that is IP65 rated at the minimum.
Don S
guaranteed to work for 10mil operations that should work right ??
You tell us when you get it installed.
Technorunner
i did already order one to try 10 min ago. With that price IF it works sure will be nice. And you can chose with the connections if you wan NO or NC. Do you happend to know how long the arm with the roller on it should be?
ktbarrentine
IMHO...The blue ink in Don's signature says it all.... After all...It is a B.O.A.T.!! I recommend go big, do it right, or risk a tow back to the ramp.....:)
Technorunner
I was bored at home so i opend the microswitch. And mercruiser was not doing it big with those switches lol. Its not sealed at all. Irepaired mine in 10 minutes after opening it i also changed min to NC since i need it for my injectionsystem. I took a pic after i made it NC but just for you to se how simple it is one of the connectors was burnt.First i drilled of the brass tubes holding it toghether. I opend it up. It took me approx 10 min with getting my drill. So i took a fine sandpaper end removed all that was burnt. Voila it works again. just puted in some batterypole greas and sealed it up with some silicone. So i canceld the order of the Microswitch since this was so easy. I will do it on my other as well.
fishrdan
I used an "off the shelf" micro switch for my MC-1's shift interrupt switch. I'm not sure how close it is to an Alpha 1, but here's a couple pics of the setup, it needs an adapter bracket. (I don't remember the switch P/N, but have posted it before, look in the archives) Been using it for the past 2-3 years without issues.
