aluminum mod
grank
i have a 22ft cuddy cabin with a sunbrella curtain - i would like to change it to aluminum with doors -any advice would be welcome
jasoutside
Re: aluminum mod
You don't happen to have some photos of what you are working on do ya? That would be uber helpful.
Welcome to iboats!:)
Re: aluminum mod
Ayuh,... Welcome Aboard,...
Got any Pictures,..??
herefishy
Re: aluminum mod
Welcome.
A picture of what it is that you want to build with aluminum would be helpful.
~Fishy
fishrdan
Re: aluminum mod
The pic didn't work. You have to "Go Advanced" and insert the pic from there. This is an undocumented feature of the forum's newest software level :rolleyes:
Re: aluminum mod
Ayuh,... I saw the picture before it disappeared,...
How big a door ya thinkin',..??
Are you thinkin' of doin' this yerself, or hirin' it out,..??
How Handy are ya, 'n how big is yer toolbox,..??
Welder,..??
There's several ways to get where ya wanta be,...
The 2 big determining factors are time, 'n money,...
How much ya spendin',..??
grank
Re: aluminum mod
i cannot weld aluminum, just wondering if there was a reasonable way of doing it
Welder,..??
herefishy
Re: aluminum mod
I am imagining there is a way, with maybe duckbills and some rivets, if you have no facility to weld nor have anyone to do it.
But we still have no idea what you want, we'd like to see pics, or maybe some visual indication of what you are looking for.
When posting your pics, choose "Go Advanced", then preview your post before you submit.
~Fishy
26aftcab454
Re: aluminum mod
grank- pre cut with cardboard patterns-see how they fit-you can use 45degree angle stock for the outside corners. reevit sheets to inside. bed the aluminum on mastic (silicone or polturethane) before you reevit them togeather.
try & post more photos-good luck.
herefishy
Re: aluminum mod
I'm thinking some of the honeycomb composite structural panel stuff is what you are looking for.
There are several with much experience with the material I refer to - I can't even recall the proper name for the stuff - but I can see it clear as a bell in your application. They'll chime in shortly with the details.
I believe your inquiry will be readily fulfilled - much to all of our (and yours) satisfaction.
~Fishy
herefishy
Re: aluminum mod
I think it's called Nicor. It is (2) aluminum Sheets bonded with a honeycomb composite material sandwiched between, to form a unitary structural panel. It is strong and lightweight.
~Fishy
island mike
Re: aluminum mod
boto nuevo.jpgI have a weird question...
Your boat is glass right?
Whats the reason you want to go with the alu??
I myself used nidacore/honeycomb, You can buy the sheets pre-glassed or glass em yourself..Light,rot,u.v, and chemical proof ,easy to cut,molde or bend,and pretty inexpensive.
I mike
island mike
Re: aluminum mod
By the way,Thats a nice rig you got there!
What kind of boat is it ?
Got more pics? inside and out please.:D
What your plans are with the doors COULD look good,I do not know how handy you are but it would take craftmanship to make it look part of the pilothouse and not something you stuck on there if you catch my drift.Again i dont know your level of handyness so to say.
If you go with composite you are looking at fiberglass,resin,possibly gelcoat,glass,etc.etc.could get expensive.:mad:
Since you do not weld yourself,If you go with the alu,You might consider to get a specialist to give you an estimate...although it would be fun to us all to have a new project on our hands!:cool:
Remember there are several materials to choose from.And welcome to i boats!
Regards I mike
ezmobee
Re: aluminum mod
I think "Coosa board" is another brand or option
grank
Re: aluminum mod
the boat is aluminum 22ft made here locally on the west coast in Canada, the aluminum used was 5083 11/32 for the hull and 1/4 inch for the rest, i was told it weighed 4500 lbs but it has never been weighed. it has suzuki outboards both 4 stroke 225, and a 9.9, suzuki was not my choice it came with the boat, always had honda but i keep an open mind. it has some things i would like to change in time. none of the windows in the cabin open and i would like a solid cuddy door. it seems a bit bow heavy because when it rains some water find its way foreward, not much but i dont like it, so a door would solve that problem unless someone could offer some other remedy, but also a boat is more secure with a solid door- i think. does one use lexan or safety glass ?????? so many questions. i will post more pics and look foreward to your advice, and thank you all for showing interest.
island mike
Re: aluminum mod
Oh,I see.
I mistook your boat for glass...
If its the water your worried about you could maybe keep it out by ways of a ledge on the deck,
I used lexan(plexiglass) but for security as you mentioned safety glass would be the way to go.
I mike
herefishy
Re: aluminum mod
Oh,I see.
I mike
but he can still use the nidacore to build a wall and install a door, right? on his alyoumeeneeum boat?
Mike, I was thinking of your project when I saw Grank's.
~Fishy
