retiredfornow
- Joined
- May 9, 2011
- 355
As a general rule, on the same style/type/pitch of prop, will a aluminum prop produce the same RPM as a stainless one? The only thing that changes is the material. Thanks.
Since stainless steel props are thinner for the same strength, there is less drag on the stainless and you will get more RPM.
Not an issue as the rotating mass of the prop is insignificant compared to the water load.Since stainless weighs more it take more power to turn it so you might see a decrease in rpm.
