Re: An outboard from the Garbage - but will it run again?
Since I am the one who said that I think the lower crank seal parts are still there, I'll elaborate here in the thread.
When you remove the powerhead from the exhaust housing (midsection) on one of these motors, and look down into the channel that the driveshaft runs through, there is a ledge cast into the forward portion of it. I confirmed this by getting into my parts bin for 5.5hp & 6hp motors yesterday.
Although I have not pulled any of my 6hp motors apart (I have three of them) in a bunch of years, I seem to remember that the crank seal parts are loosely held in place by this ledge. When you insert the driveshaft up, into the exhaust housing, with the drive shaft pin in place, the pin pushes against the seal spring washer, compresses the spring, and then pushes the remaining parts in place. This creates the desired seal for the bottom of the crankshaft.
I'm not going to say that this is positively the case, because its been too long since I have had one of my 6hp powerheads off, but I think it is so. As such, I think the parts will be found in this motor when he pulls his powerhead to deal with the shift rod problem. Since he has to do this anyway, there is no harm in either proving or disproving my recollection.
As for installing a new head gasket, you can't lose by doing that either. The service manual actually calls for this as part of the tuneup procedure. As motors were manually decarbed before products like Seafoam and OMC Engine Tuner (the stuff in the can) were around, this was an accepted part of tuneup practice. I would say to just go ahead and pull the head, because replacing the head gasket will remove it as a possibility for lower compression. While your there, you may as well decarb the motor the old fashioned way.
PS: When you pull the seven small bolts that hold the powerhead to the exhaust housing, pay attention to where they came from - I seem to remember that one or two of them are longer than the rest.
