JamieScott
- Joined
- Apr 4, 2008
- 28
Re: An outboard from the Garbage - but will it run again?
Thanks for you last few posts guys.
I'm getting closer now to getting it back together and the big test run in a tank.
I'm hoping that the water jackets are not blocked up as you are right the motor most likely has been used in salt water. If there's problems with the water flow then I will have to go deeper but I will cross my fingers that's not the case.
I've got all the bits that I need now and am going to try to get it back together tonight. All I have to do is connect up the shift rod to the shift rod lever - put in the new top of driveshaft o-ring and seal - put the powerhead back onto the exhaust hosing with a new gasket in place - reconnect the levers to the carby - attempt to get the lower gearcase housing section all lined up and back on. The only thing that's stopping me from testing it is after that is that I've not got a fuel tank or fuel line yet so that's going to slow things up.
There is a telltale on this motor. Its a small rubber pipe with a plastic pee hole on the end that exits just below the lower spark plug.
Will update soon
Jamie
Will update soon
Jamie
