Re: Any Linux users?
Boomyal,<br />You said "I did verify the bios setting and the CD does show the whole ISO file."<br /><br />Is there only one file (the xxxx.iso) on the cd you burned?? If the answer is yes, you burned it wrong. <br /><br />Nero destructions:<br /><br />Version 5.x<br /><br /> 1. Launch Nero.<br /> 2. Choose File, Burn Image and you'll be presented with a dialog box.<br /> 3. Click on the Files of type: dropdown box and select All Files (*.*).<br /> 4. Select the .ISO file you downloaded then press Open.<br /> 5. Next, Nero will show another dialog box of CD burning options. Accept the defaults:<br /> * Type of Image: Data Mode 1<br /> * Block size (Bytes): 2048<br /> * Image header (Bytes): 0<br /> * Image trailer (Bytes): 0) <br /> 6. Choose OK.<br /> 7. The Write CD dialog box should appear next.<br /> 8. Make sure Write, Finalize CD, and Disc-At-Once are checked, then choose Write. <br /><br />Tips:<br /><br /> *<br /><br /> You must use the Finalize CD and Disc-At-Once option in Nero, or you will get the error: "FATAL ERROR: Installation of side by side assemblies failed" during setup.<br /> *<br /><br /> You must specify *.* for the file type to see the .ISO file.<br /><br />Version 6.x<br /><br /> 1. Launch Nero.<br /> 2. Choose Recorder / Burn image<br /> 3. Browse to the location of the ISO file and select the ISO file you want to burn to cd/dvd<br /> 4. Check the option "Finalize CD (No further writing possible!)<br /> 5. Click on "Burn" now.
