Aplha One cavitation plate busted - I am an idiot
frankttaylor
Specs:
1990 Bluewater
3.7 Liter
Engine Serial# OC768011
Transome Serial# OC892745
OD Serial# OD306211
This past weekend I was using trolling plate that is mounted to cavitation plate and forgot to release the trolling plate before accelerating. I managed to bust up the cavitation plate (see pic). I see there are replacement parts available. Does the damage appear too bad to repair? I have a spare lower unit but the skag needs repair and it appears to have hit something very hard (prop trashed and trim tab busted). Not too sure I trust replacement. Should I look for a different out drive? Thoughts?My Cavitation plate.jpg
series60
Re: Aplha One cavitation plate busted - I am an idiot
Specs:
1990 Bluewater
3.7 Liter
OD Serial# OD306211
This past weekend I was using trolling plate that is mounted to cavitation plate and forgot to release the trolling plate before accelerating. I managed to bust up the cavitation plate (see pic). I see there are replacement parts available. Does the damage appear too bad to repair? I have a spare lower unit but the skag needs repair and it appears to have hit something very hard (prop trashed and trim tab busted). Not too sure I trust replacement. Should I look for a different out drive? Thoughts?View attachment 164787
Take the lower unit off and take it to a GOOD aluminum welder.
81 Checkmate
Nope shouldnt need the old pieces.....A good fabricator can make his own.
Check out a picture of mine and i repaired it myself.......0514121536b.jpg0515121130a.jpg
Crapy pics but you get the idea.......
frankttaylor
Check out a picture of mine and i repaired it myself.......View attachment 164792View attachment 164793
So your eally don't see any reason why I should buy the replacement parts and it would be just as cheap to have a fab shop fab them up?
Ayuh,... That's what he's sayin', 'n that's what I'd do,... fab 'em up, 'n weld 'em in...
Then grind it out, 'n paint it...
That's the reason I advocate over-sized trim tabs, 'n drift socks for speed control....
frankttaylor
I agree on that last point. There is now way I will put a trolling plate on there again. besides it decreases overall performance and effiiciency with the extra drag from the trolling plate. Over sized trim tab will help also?
Ayuh,.... It's been discussed in, I Believe, the Fishin' forum....
Btw,.... Smart tabs builds a Special fisherman's model...
Not takin' any credit, but John Intro'ed 'em 'bout 6 months after our conversation 'bout such a thing....
frankttaylor
I guess my concernb is still that it will affect performance when not needed.
Do you think a dophin fin be a good option?
Frank,.... As I said, this has been discussed in other forums...
yer Off-Topic for discussions in THIS forum....
