redwhite_blue
Thread starter- Joined
- Sep 13, 2010
- 16
I am rebuilding a 93 SeaSwirl SE190. The boat is not that old, but my brother put her on the shore in July 2010. the damage was minimal along the keel, and the boat bottom. The worst damage was to the nose of the bow. I was crushed pretty good. Bottom line, I decided to gut the boat and redue it inside and out. Enough about my project.
I have been soaking up as much as I can from this forum, but I am not sure I can do what I want to do with the gel, when I re-gel my boat.
My question is about masking and gel-coat. Is it practical to mask and stencil onto gelcoat?
For example, I am looking to spray the body color, then the candy stripe, and as a last step I want to stencil over the body color with a different color. The name of the boat will be "Faded Glory" So you can imagine an antique white body, an antique red candy stripe with stenciled stripes on the body, and then stars stenciled on the body in an antique blue.
does the masking have to come off before the cure, or can it be pulled off after the cure. Or is it just an impractical expectation to do this detail of work with gel coat?
Thanks for your time.
