Aq131A Video Please Help
Status
Not open for further replies.
Brucetafer
Re: Aq131A Video Please Help
no vacuum ports on there,
now im screwed, i cant for the life of me get the crank bolt out, cant get a impact in there, so a breaker bar it is, but no luck getting it off...
so im not thinking straight, if i line up all the lines on the timing belt with the pullys, im good to go right? i know theres a compression and exhaust stroke for the crank but it still is the same as long as it lines up... im so tired of tinkering its rediculous... any advice would rock...
Brucetafer
i know some of you will yell at me, but can i do the starter trick to get the crank bolt off??? thanks..
picklenjim
That is correct. The belt supposedly has a double line on it to line with the mark on the crank. Intermediate and cam have a single line on the belt.
So is the problem the crank keeps turning as you try to loosen the bolt. If you have a strap wrench you can try putting it on the pulley to hold it.
Brucetafer
yeah theres 2 lines for the crank and i have to push it down to make sure its good, ive tried everything to get that crank off, impact wrench couldnt get it off, 3 foot breaker bar just bends the crank holder i have... i put a ton of liquid wrench on it so hopefully it helps...
proshadetree
I am going to get slammed for this but have you hit it straight on with a hammer? Helps on some bolts.
Brucetafer
was going to try that, but its a crankshaft, ive tried that before and ruined a CR125 motor that way...
Brucetafer
ok, this is horse crap, i cannot for the life of me get that bolt off.... anything else i can try other than buying a volvo crank tool???
sqbtr
Have you tried the starter trick?
I don't understand
Didn't think long enough. If your crank holder is bending you can always pull the starter and use the flywheel ring gear to hold.
picklenjim
Here's something you can try. With the old belt on the crank pulley pinch it together and pull tight straight up. DO NOT HAVE IT GOING AROUND THE INTERMEDIATE PULLEY. Now keeping it pinched together go around the old tensioner pulley and pull down hard. Now while pulling it down tight put it together with the belt coming up from the crank and clamp all 4 thickness's of belt together with a c-clamp or such.
Brucetafer
got the bolt off with the starter trick, worked perfectly... now the pulley is ON there, tried a wheel puller and bent that,,, jesus,,, oh well gonna get a bigger better one and let the liquid wrench sit for a night... thanks for the help guys... im almost there... i found that the belt is REALLY stretched and off a tooth so theres my answer... cant wait to go fishing!!!!!
sqbtr
Never had much luck using a puller on a tight balancer, opposing pry bars work the best.
Brucetafer
dont have the room, im almost ready to pull the motor... tried a bigger wheel puller, and it started to work, but cant get it all the way off, i need a different puller, this one is a specific model for ford... crap..
sqbtr
If it has started to move, soak the back side with a mix of acetone and ATF. Push it back on and keep working it in and out. I would take a close look at the raw water pump for leaks out the rear seal if the balancer is that hard to pull.
picklenjim
No balancer on this. Just a pulley which fits the crank tightly like a balancer would.
Are there any threaded holes in the pulley which you could use a crows foot puller with?
sqbtr
Penta refers to it as ( 855476, Vibration damper)
Not a true harmonic balancer as there is no rubber damper in it.
Brucetafer
ordered a 10 inch CUMMINS DAMPER PULLER, Lol, i have a couple cummins and always need to replace those, might as well... i was called to florida for the PGA show, so ill be there till the 29th, if anybody lives in florida and wants to take me fishing, IM DOWN!!! lol, im probably going to move there in 6 months, work calls...
Brucetafer
well, after 3 hours of trying and trying, im done trying to get this off... theres no way its going to budge... any thoughts??
Brucetafer
well, now im in a big hole... took the boat to volvo, they tried to get the pulley off, no luck, took it home, and found the back pulley is chipped off.... im screwed... anybody know if that one is the same as a car???? or am i just going to have to look for a new one...
also the pulley is STILL on there... even used the factory puller from volvo to remove it..
sqbtr
83 volvo 240 sedan $100 at NAPA
picklenjim
Sounds like about all you can do now is cut it off and get a new one. I would take a reciprocating saw and cut away about 1/3 of the pulley down to the center hub of the pulley which is in contact with the crank. Then I would use a fiber cut off wheel in a dremel tool to cut away an area of the center hub of the pulley down to the crank. The pulley should then seperate enough at the cut to be loose and come off. By looking at the picture #288 on page 91 in the manual it doesn't look like it's really on the shaft that far. I've cut bearing races like this before with dremel tools to get them off shafts.
Status
