Clams Canino
- Joined
- Jan 10, 2004
- 2,179
Re: "Authorized Dealers?" - Think Twice
I mostly agree with Rodbolt here, with a note that the walls could as likely be fine as not. Most of the ones I see are only a couple thousants out of spec and run-in just fine. A *little* taper is OK too as it helps keep the rings from sticking. But AGAIN this is where you are at a disadvantage with a Merc dealer. Brunswick is selling those pistons for $150 each while there are good new aftermarket pistons out there for 1/2 that. Boring the whole thing .015 over becomes more of an option when you know this.<br /><br />As for the exhaust divider plate, that's a crapshoot. If it was freshwater it's prolly not an issue, and he well may have inspected it. Doing that inspection (assuming the bolts come out OK) adds about 1.5 hours and two gaskets to the bill. Most of that time is spent preparing the gasket surfaces and chasing the threads in the bolt holes with a tap.<br /><br />-WOriginally posted by rodbolt:<br /> hello<br /> with no rebore I dont trust the job. no way those cyl walls are straight. <br /> and if the exhaust divider plate was not removed for inspection and the motor has been in the salt pond it gets iffy.<br />
