And the terminals covered to prevent accidental shorts/sparks.The battery does not have to be in a box..just secured.
Why? Onboard chargers are all potted so there would never be a spark.I like a vented, dry area for my battery but I don't like my charger to be in the same vented box as the battery.
I had some home made seats in mine before I started the restoration. I had my battery mounted the same way, in the seat box. I really liked it there, the balance of the boat worked better getting a little more weight forward. I am going back with factory back to back seats. Since it is a 16 foot boat, I have to use the smaller back to back seats. Can anyone with back to backs tell me if they have enough room for batteries under them? I assume not, thats why i am putting the batts aft in the factory location.
You could use that dough to buy a couple more Rapala's and a flat of beer.
Now you have me thinking! You know, I do have a good charger on the bench, no need complicating things. For what those fancy chargers cost, I could probably buy a pallet of beer.
Still building the nifty enclosure though.
Well if the batteries have exploded, you have already had the worst case scenario so not sure if it could get any worse with a battery charger in there.
How did your batteries explode? Seems that the only way would be if they were overcharging, gassing a lot and a spark occured.
Just curious since I have my charger around 6 inches from one of my batteries.
I see what you are saying. Probably depends a lot on the size of the enclosed area and how the heat can get out.But I don't like my charger in a battery box. I'm just not comfortable about the additional heat the charger puts out.
