Spooner2010
Thread starter- Joined
- Dec 1, 2010
- 96
I have done the search and have found many answers to many of my questions. HOWEVER.
Quick skinny? 16? aluminum fishing boat. Anything electrical was cut and stripped by previous owner. No switches left, no breakers, no nothing. Just ignition wire and starter cables. So pretty much clean slate. I can wire it how I want (basically how you guys tell me). In other words I could end up wiring it wrong. That?s why I?m here.
I bought 3 switch panels and 1 breaker panel. See pix.
Among the hundred questions I have one that jumps out at me and I have not been able to find in searches is this. In my research I have found that all wires must start with a positive connection and end with a negative connection. The ?loop?. Where I become puzzled is if I have a breaker panel with 14 breakers, then that would equal 14 wires coming IN on one side of the panel and 14 wires coming OUT of the other side of the panel. Does that mean that 14 wires will connect to the positive battery post and 14 wires will connect to the negative post? Common sense would say this is not the case so how do you change one wire off the battery into 14 wires going into the breaker panel?
Next question is this. The switches on two of the panels have a red light on the switch to indicate that it is on. On the back of these switches there are 3 prongs. I?m guessing one is to luminate the little red light when it?s on. So how does that get wired? Pig tail off the downstream side?
I have several other questions but I leave you guys to chew on this one for tonight.
Thanks in advance guys.
