Re: Best oil filter???
I use the toilet paper filters in my shop and have no lint problem, they are probably the best water saparator you can use. I also put one just before the bead blaster and on the sand blaster.<br /><br />As to using them for an oil filter, they work great, they do not come apart at all, and you use the cheapest unsented single ply paper you can find. They are indeed used as a bypass filter, and as long as the paper is clean so will be your oil. They do not filter additives either. Keeps you oil anilitacally clean. Your oil allways looks new.<br /><br />Also, if you think that your oil filter is filtering "ALL" of the oil that comes from your oil pump all the time, you have another thing comming, Your bypass valve may be by passing as much as 50% of the oil your pump actually picks up. Also, a slightly restrictive filter will have no effect on your actual oil preasure due to the restriction inside your engine, much different that the oil filter test that is just pushing oil right on through. On a high RPM engine as in a boat or racing though, I would want a lower restriction filter.
