Black Box
user-name
My boat had a merc 470 package.
Now It has AQ131d/SP package.
The installer did a very good job on the wiring the VP to the old Glasply dash.
Here's were I'm scratching my head. The Tilt Trim Gear assembly is shot. Motor seams OK
So i look at ebay to see what one is going for.
I dont have that BB. Do I need it? whats it for?
Don S
Re: Black Box
Post a picture of your trim/tilt unit.
The one you have pictured is a an electro mechanical lift found on 270 & 280 drives. No tilt involved.
You should have something like this for your SP
user-name
Re: Black Box
My Pics are failing. I dont know how to resize my photos.
Anyway
I do not have what you have Hydraulic style like you show posted.
I guess I have what you call the electro mechanical lift. Just like the ebay pic without the BB.
The Installer Used a ON/OFF/ON rocker switch powered from a bus bolt on dash. Out of the switch are TWO wires that go strait to the motor. No BB
Don S
Re: Black Box
Then you don't have a 290, the lift ended with the 280 drives.
The black box has the relays in it for up and down, you won't pull the amperage needed going through the switch to raise the drive.
user-name
Re: Black Box
Thank you again Don
Black box === Will Going on I know of a unit in Lake Stevens.
BTW I do have a SP hanging off the back of the Intermediate housing . Used boats,,,, who know what they used to fix them.
RogersJetboat454
Re: Black Box
User-name,
You wouldn't happen to have any sort of Microsoft office version on your PC?
Allot of the MS offices come with Microsoft Office Picture Manager which features several functions including re-sizing pictures.
The Icon would look like this;
If you don't see it, but have MS office, open your programs, and go to the Microsoft Office folder. You may find it in there.
Don S
Re: Black Box
Does your transom shield look like the top or bottom picture?
Don S
Re: Black Box
You just posted the thumbnails, not the actual pictures. They don't get any bigger. But those are good enough for what I was trying to find out.
What you have is a bunch of different parts stuck together. The upper gear box is an SP-A, but that's all. The intermediate section is a 280 or 275, and so is the transom shield.
You need the black box and wiring for a 280 to make it work right.
user-name
Re: Black Box
Don
You sure aren't kidding (What you have is a bunch of different parts stuck together.)
Got the relay box last night.
Looks like a easy hook up.
Battery
Motor
3 way Wire ===== Hook up to my existing switch
relay up
relay down
Idiot light----- I'll void that.
