4bait
- Joined
- Dec 27, 2008
- 51
Re: Buick V6 conversion
Since the shipment turned up I have a whole swag of new bits to play with and make fit.
Here is the Mercruiser drive plate machined down centred up and redrilled to suit the Holden Flywheel,
Next was to get the Mercruiser chevy bell housing to fit, Tried it on and the 2 top holes came close to lining up so I elongated them a bit and got it to bolt on in the correct position, Then started drilling out the remaining holes and was preparing to weld on some lugs for the mounting position, then thought it was too big and stuck out in all the wrong places, it would have done the job but it looked crap. I want the conversion to look like it's mean't to be there and not just bits and peices tacked in here and there. so I scrapped the idea and went to plan B.
This is the Chev Bell housing on the block for any one interested to see how different they are. Also the starter motor cutout was on the wrong side. The white line shows where I was going to cut it off before changing my mind.
it's not crooked I just took the pic on a funny angle sorry
Plan B was to cut the front of an old VN Commodore T700 auto transmission. (lucky me I had one sitting around spare after I put the same Motor in to my Hilux)
Here is the cut off section bolted to the block
Then I cut the middle out of the Chevy bell housing and spent about 3 hours lining them up in the correct position (hopefully) before welding the two together to make one.
And heres a pic of it fitted to the engine block
Hopefully it is all welded together in the correct position, but I will find out for sure on Wednesday when I bolt the transom assy to the boat and sit the motor in so fingers crossed.
I did bolt the transom plate to the bellhousing and put the alignment bar in and the bar came through the centre of the hole, but this can change depending on the angle of the transom and whether or not I had the plate sitting on the exact same angle, ( hopefully my angle Gauge doesn?t lie LOL)
Cheers Andy
Cheers Andy
