4bait
- Joined
- Dec 27, 2008
- 51
Re: Buick V6 conversion
I Think I have the interrupt sorted out now, I have put in an extra relay that is activated from the old interrupt switch, the relay then cuts power to 3 injectors on the starboard side which nicely drops the rpm to about 300 momentarily allowing the gears to disengage.
Works in the test tank anyway and when the interrupt wasn't hooked up in the test tank it was definitely harder to get into neutral.
Hopefully a water test on Wednesday will confirm but if it needs more then I can easily hook up a few more injectors as well.
The only problem is that it takes a couple of seconds before the motor returns to normal, I suspect the old interrupt switch is sticking and hanging on.
Heres a pic of the water proof box I put in for the computer and stuff for those who are interested.
I used an Ice box so it is also insulated from heat and cold and it is tucked up under the transom behind the rear seat.
I have a little bit of Glass work to tidy it all up a bit more.
Cheers Andy
Cheers Andy
