Can anyone tell me what year and hp this motor is?
Fun Times
B115204 Is the number on the Welch plug
That is your serial number and the engine is coming up as an MERCURY 20 HP M (Manual start) model number 1020207 which makes the year a 1987.
Search the model number online for a parts catalog.
flyingscott
Very easy to put electric start on that motor hard part is finding the tiller switch. You just need to find the parts or go to a mercury dealer and see if they still make a kit.
Chinewalker
Yep, easy to do, but not cheap. Might be better off finding a parts motor with the parts you need - starter, wiring, flywheel.
flyingscott
it is fairly cheap to put electric start on most of the parts you can get used and you don't need the whole flywheel. Mercury uses a ring gear not a separate flywheel assembly like OMC. The hard part is the tiller switch which you can find on ebay as NOS
zackduncan40
I think mine already has the button in the end of the tiller handle! Is it a little red push button? That is the only thing I could see it being because the kill switch is on the side of the motor
zackduncan40
And also I need a carburetor rebuild kit for it... And I can't find the one I need on iboats.. Can one of you post a link or a product number for me to search please? When I put in the model #1020207 nothing came up so I'm not really sure what to get.. Thanks guys!
flyingscott
Red button is a kill switch not a start switch. The correct serial # to look up parts for your motor is 0B115204. Merc goes by serial # for parts look up get the carb kit that has the fuel pump and primer assembly gaskets.
zackduncan40
@flyingscott: on iboats when I search the model number or the serial number nothing comes up... Do you know a part number I could search for the rebuild kit?
flyingscott
1395-9761 1 is the mercury part#
1395-823707 2 is another mercury part # probably don't need that one. double check these #s
zackduncan40
Can one of you give me the part number for the electric starter kit that gives me everything that I need to make my motor electric start or give me a list of parts I need? Thanks guys!
