jrttoday
Thread starter- Joined
- Feb 8, 2010
- 1,081
am curious too, this is the 3rd or 4th time I've changed from starting. But, think this is the final direction; it IS quite a bit of material - that I-beam is "light" but will be trimmed down later. Haven't weighed it yet, but doubt it will not be much heavier than a stock swivel bracket for this t/t unit.
9/16" plate it's laying on is the one I welded together - 13" x 15" and only weighs 10lbs, not going to use it, making smaller plate from 1/2" material.
On the lighter side, if it doesn't float or just doesn't work; I'd recommend investing in pacifiers cos I'll be crying!!! :facepalm: There's an unspoken rule about buying steel at the scrapyard - I'll recycle whatever isn't used.....
I'm an old stick welder too; wire welding is for people that can't burn a rod, imho. However!!,stick aluminum is for the birds......
Regardless, just saying what "might" be obvious? Aluminum MIG is NOT very forgiving; it's a "whole body" kind of welding and not "just" in your wrists. But my gun and whip are very stiff; and not using a spool gun to pull wire adds to the difficulty.
Big wire on small pieces in small paces is another hurdle; and having to brace everything to keep them from distorting makes it more difficult to weld. Because this isn't a casting, there going to be many little gussets etc to stiffen it up - and it takes awhile to make 'em.
