jrttoday
Thread starter- Joined
- Feb 8, 2010
- 1,081
two 1/2" plates fitted together for each side - the added plate is for head clearance on 5/8" bolts through transom; t/t mounts to that. Which will allow "some" lol downward movement IF I'm too high; w/o having to redo a bunch!!!
I quit using flash cos you really couldn't see; maybe try red eye reduction? :lol: The bead on bottom plate was one big wash; don't need strength there, just tie in from being beveled.
If ya can see that bead on top that ends at the burr bit; top bead welded first, then bottom bead. Typically, that's how I weld ally, top bead then come back with the bottom - carbon steel the other way. No worries of trapping slag, complete fusion is what you want. It seldom makes much difference how your beads look - COMPLETE FUSION is what's critical.
I have no doubt cheap or small MIG welders CAN make prettier welds, but they cannot weld this big wire. NOR, can they weld thick aluminum; voltage, wire speed, and large wire is how to get penetration
