Can you fill scores in a piston with JB Weld ?
spybot
Piston is scored from a heat seize all sores are below the rings
Some are 1mm deep.
Can they be filled with JB Weld and reused ?
Honorary Supreme Mariner
Yes they can be re-used.----GGRReat stuff that JB weld.------Also look into some stuff called --:" lumiweld "
spybot
Thank you Racerone
Yet again you come to the rescue
Joe Reeves
Some are 1mm deep.
For yourself as an experiment?...... Perhaps.
For a customer, a repair under warranty?..... Not likely.
spybot
This is just so i can sell the engine
I cant justify spending £180 on new pistons
For what i will get for the engine.
Prior to the strip down the motor (1980 V4 85 hp) i was getting 110 psi on all 4 pots
That was with the scoring and 3 stuck rings
This is why i need to know if it will work
F_R
So you can sell the engine??? Got a conscience?
Spy, could you explain to us what you understand by these terms.--------" rebuilt "----" refurbished "---" cobbled up " -----And " junk " so I can sell it !!!
spybot
Ok guys got the message
Bin the pistons and order new ones
spybot
Number 1 mint
Number 2 OK for use by someone else
Number 3 OK for my self to use
Number 4 BIN
I understand guys and No i wouldn't sell something to someone if i had any doubt in my mind.
I have been stung twice and would never sting anyone.
I am a decent guy that is still learning about out boards from you guys.
Thank you for confirming what i already thought.
New piston will be ordered
spybot
Can any one tell me if this part number piston will fit a std V4
OMC Johnson Evinrude Piston Part Number - 318522
Joe Reeves
I don't see that number in the parts book... What's the model number of the engine?
spybot
The model number is J85TLCSA
There are a few different ones i have looked at joe but none match my model number for the pistons which is 0385661
The BRP number is 390981
The other part numbers i have are the following
OMC Johnson Evinrude Piston - P/N 319271
OMC Johnson Evinrude Piston Part Number - 385867
Andy
spybot
Mind your P&Qs, Spybot.
We do not not take kindly to name calling.
Mod Team
For your information.-----3.500 crossflow motors use the same standard piston from 1974 to 1998 models.
spybot
Thank you again
I will just order the set if they dont fit send them back and get the other ect ect
you need your final bore prior to ording new pistons anyway. what bore did the cylinder walls clean up to?
spybot
They are still standard
They all come up with a hone.
Have you measured the bores with your 3-4 " micrometer and telescopic gauges ??
boobie
I've found that Gray Marine-Tex works a lot better than JB Weld.
