BillaVista
- Joined
- Jul 1, 2013
- 204
I have two problem conditions - may be related, or may be two separate issues.
Condition 1: Engine hard to start if it isn't dead cold or thoroughly warmed up, has rough idle (drops a few hundred rpm them recovers - don't know if it is "stumble" or a "miss"), and most recently has taken to stalling when put in gear (forward or reverse) even if warmed up.
History: Has always (since I purchased at beginning of this summer) been hard to start if it isn't dead cold or thoroughly warmed up, but I originally attributed this to my ignorance of procedure (use the start lever or not? prime again or not? choke or not?). If it is dead cold and I put the start lever to start and push key for choke, it fires first time. But if it quits before thoroughly warmed up is is a complete $%#@ to try and re-start - I have tried all manner of combinations of prime/lever/choke.
But if it started and kept running it ran well and good performance.
More recently, it has begun to stumble/miss at idle - almost quits but recovers. Never at rpm, just at idle. Sometimes it does just quit.
Most recently, it has begun to stall and quit when being put in gear, even if it has warmed up fully.
Condition 2: I noticed what seems to be excessive oil in the bottom of the compartment, seems to originate from the air box. If it were a car/truck I would suspect excessive crankcase blow-by, probably caused by worn rings / scored cylinder walls. Don't know if that is a good assumption for this 2-stroke OB?
Spark seems good, have changed plugs 3 times, plus always seem a bit oil fouled. Also seems to me to be excessive oil at the spark plug hole but then again, I have little experience with OBs so no real frame of reference.
I figure a carb rebuild is in order first, then a thing I think is called "link and sync" (kind of a boat motor tune-up I believe).
The oil I'm not sure about - I guess I could pull the head and have a look at the piston/rings/cylinder walls.
Does any of this sound familiar or common? Any other places to start?
Here are some pics of the oil in the housing:
As seen from port side:
As seen from stbd side:
