colud a tune up solve my problems
MCM
Re: colud a tune up solve my problems
I know they're not the same but its probably the exact same part? They don't make a different carb for every horse power motor they build.<br /><br />Buy a manual & a parts manual, then you'll know for sure.<br /><br />Mike :D
redsxhater04
can anyone help on the ajustment needle. using this link you will see what im talking about, when i got the motor it was tightened all the way which must be wrong. this part number is number 21 and 22 on the link that MCM has listed a few lists up. any coments asap would be great.<br /><br />thanks, steve :)
MCM
Steve, you need to get a manual for that motor, it will explain about everything you need to know to make it run right, I don't have a clue what the settings for that carb would be, but the manual will ;) <br /><br />Mike
dajohnson53
Steve - it sounds to me like you're new to outboards and don't have much experience operating or fixing them (no criticism intended, I'm no good at it either). I also understand you bought this motor from a dealer. You should go back to the dealer and they should show you how to operate this engine - how to start it, how the choke works, how to mix gas, etc. etc. If it doesn't run right, they should make it run right since they said it was ready to go. Perhaps you will have to pay for a tune up, but maybe not. but if you don't know how to operate it or what is normal and what is not normal, I'd get back to the dealer and ask for some guidance. Good luck
redsxhater04
hi guys ive been looking on online site for an hour now and cant find a manual for this motor. any reccomended sites or places to get the manual. one agian the model is he2reic. and it is a 2.3 hp evinrude<br />any reccomendations are greatly appreciated. <br /><br /> thanks,<br /> steve
dajohnson53
look at mastertechmarine.com (AKA maxrules.com) if you haven't already. If you don't find what you're looking for, give him a call - he's a great guy and will do what he can to get you what you need.
sprouticus
you have a fuel leak, replace your fuel line..cheap and easy fix. And for the record, after you start your engine, push the leaver that activates your choke back in......this will turn a buterfly valve on your carb to a horizontal position, allowing your engine to run leaner, giving you more power and much better fuel economy.
redsxhater04
sprouticus i dont think it is the fuel lines though because yesterday i ran it in a tank and noticed that alot of fuel is gathering up in the carb and leaking.<br /> steve
steamboatwilly
sprouticus i dont think it is the fuel lines though because yesterday i ran it in a tank and noticed that alot of fuel is gathering up in the carb and leaking.<br />steve According to this statement,the float is too high.The float is not shutting the fuel off.
MCM
Steve the float is locted in the carburetor.<br /><br />Which is why if you plan on doing this and not making the problem you've got worse you need to get a manual.<br /><br />If you look at the Ebay link about 5 or 6 posts up you'll see that the manual for your motor covers the 2.3hp, 3.3hp 4hp, 5hp, 6hp, 6.5hp and the 8hp motors for that year.<br /><br />The section that covers carb rebuilds and adjustments also covers the float setting.<br /><br />Here is a link to the manual for your motor, it's $65.98 at Ken Cooks,<br /><br /> http://www.kencook.com/evinrudejohnsonmanuals/index.cfm?fuseaction=models.main&year=1991&ID=108880 <br /><br />Or you could get the one for $32.95 at this link<br /><br /> http://cgi.ebay.com/ebaymotors/2-3-...ryZ26453QQssPageNameZWD1VQQrdZ1QQcmdZViewItem <br /><br />Same service manual, either way you are going to have a very dificult time without one.<br /><br />Good Luck Steve ;)
redsxhater04
ok guys here it it, i got the maual and got a parts catalog. i fixed the float and put on some new stuff. after doing all this i finnaly got my call back from the dealer and he said to bring it in so we n fix it for you......but hey at least i leaned something!<br /> thanks guys im sure ill be back soon<br /> steve
MCM
Glad to here it Steve :p
