confused on oil mix ratio need help
bigboi
i have a 1993 javelin with a 1993 johnson 175 faststrike my uncle owned the boat before me and we used to always go fishing in it etc so i not only bought the boat for great fishing but for the memories with my uncle its a great boat but i remember when he had it the oil injection quit working so we just unhooked it and started premixing and i believe we did the 100:1 ratio which is 13oz of oil to 10 gallons of gas so when i bought the boat i did this and it runs great it has no problems except that when my uncle drove the boat we usually went 60-70mph and all i can get it to do is 50-52 non gps note to that i am considerably bigger than my late uncle. ive also been told that all outboards take a 50:1 ration which i believe is 26 oz of oil to 10 gallons of gas according to my quicksilver bottle which is the oil i use... any input is greatly appreciated thank in advance...
bigboi
Re: confused on oil mix ratio need help
my question is if it happens to be 100:1 and i do 50:1 can i mess anything up by over oiling and how will i know if im over/ under oiling
emdsapmgr
You are not oiling that engine properly at 100 to 1. That is half the oil that engine needs to run reliably. If you follow the mixing ratios on most marine oil bottles, you will get it correct at 50 to 1. Your 26 oz of oil in 10 gallons of fuel is on target. I'd probably recheck the compression on all 6 cylinders to make sure the powerhead is not damaged.
JB
If you "over" oil you might notice more smoke. If you "under" oil you might notice a variety of symptoms of a broken engine.
Raystownboater
More smoke and fouled plugs seems far better than a total rebuild, IMHO
50::1 ratio will not foul plugs in a properly tuned engine. Heck, we used to run 24::1 in a motor with points/magneto ignition with nary a fouled plug.
Raystownboater
Over oiling runs the "risk" of fouling plugs and under oiling "risks" damage to the engine. 50:1 is the ideal mixture but If I had to choose other than 50:1 I would definitely lean towards too much oil
bigboi
thanks for the input guys boats is almost empty i havent ran but 15 gallons thru it in the 50:1 so ima put 10 in tommorow and use the 26 oz of oil and see what happens i agree completly with yall do you think it will help me get some more of my speed back to?? just wondering
Haffiman
Do a compression test and post the results.
Hydra-sport_Road-kill
I'm not thinking the correct oil mixture is going to get you back to the kind of speed you report but staying out of the service bay is most important at this point. I'm having a difficult time with the speed story. You said you were with your late uncle back then and the boat would do 60-70 but now you're alone and have gotten bigger (me too by the way) but have lost 20 mph. I'm guessing a Javelin with a 175 properly tuned should do a might better than 52 unless your a real Hoss. I mean that friendly 'cause my dad could sink most bass boats in this state.
1946Zephyr
There were certain years, mostly in the late '80's, where OMC designed motors to run on 100:1, but soon realized that was not good and ended up recalling. These motors could have been built in the '90's as well. Anything that says 100:1, ignore it. No motor should be run on anything less than 50:1. Actually, a motor that spends a lot of time at WOT, would be good to run at 32:1 and that includes newer motors as well. A little more oil will only prolong the life of your motor. It's a lot of low RPM's for trolling, that typically fouls out plugs and this is where leaner mixes are safer.
Dhadley
You could run that motor at 100:1 if you use a full synthetic oil like XD100. At 50:1 (quart of oil to 12 gal fuel) you can use any TCWIII rated oil but the partial synthetic like XD50 is most popular. Even using XD50 at 24:1 (double oil) you won't foul the plugs as long as you use the correct Champion plug. Always use fresh 87 octane fuel.
bigboi
put five gallons in this morning used 13oz of oil and believe it or not it smoked less thank it did when i was using 100:1 ran like a champ quick out of the hole got on plane good and got up to 54 mph lol.. thanks guys im going to do a compression check and all this winter my brother in law has a mechanic shop so ima take it up there where i have all the nessasary tools.. just wanna get a few more last fishes in before the real cold hits here in alabama
1946Zephyr
I would never run anything 100:1, synthetic, or otherwise. Oil is the cheapest thing you can put in an engine. :D
fshrgy99
LOLOL
Man, I would loooove to go fishin in the 'real cold' in Alabama!
fshrgy99 in Ontario
where 'hard water' fishing is done in the 'real cold' :)
bigboi
man as long as there pullin water im goin fishing lol haha the best fishing is done when its cold here in alabama maybe ill catch me a trophy bass
