Re: Conversion from VRO to non-VRO - '89 Evinrude 50 hook up particulars
This really ended up an easy job. If you are nervous about doing this yourself, don't be, for if I can do it you can. For those that may be interested and have any lasting advice - Here is how I handled my VRO conversion to premix fuel pump on my 1989 Evinrude 50 hp outboard.
New items for conversion
Sierra Fuel Pump - #18-7352
Fuel Pump for Johnson/Evinrude 382354 385781 388268 394543 395713 398338 398387 432451 433387 438556 - Sierra 18-7352 - iboats
Fuel Manifold - #395540 (OMC)
Fuel Hoses - not needed can use current hoses but I figured if I am at it then why not do the whole schebang.
- 2.5 feet of 5/32 for hooking up Fuel Manifold to Carbs, carb to carb connection, primer and the air in-take drain the bottom of crank case.
4.5" from bottom carb to bottom manifold connection, 8.5" from middle manifold connection to primer (thing with red switch on the opposite side of engine from new fuel pump) 5.5 inches from top carb to top manifold connection and 8" from air intake drain to crank case
- 13" of 3/8" hose to connect fuel tank to fuel pump intake connection.
- 13" of 5/16" hose to connect fuel pump gas out to fuel manifold gas in connection (largest of the four connections).
The fuel pump in connection was a little to big for the 5/16" hose so the 3/8" was needed.
With the exception of the hoses all connected to the fuel manifold, I took the hoses off one by one, measured, cut and installed the new hoses as I went along. I figured there was less chance of screwing things up this way.
Stumbers for me
This is the pulse line for the old VRO that needs to be plugged up.
This is the air intake drain nipple that is hooked up to the connection to the crank case.
I took the primer solenoid off in order to hook up the hose from the manifold to the primer solenoid. The primer connection is on the back so it is almost impossible to get at without a disconnect. Only two bolts so not a big deal.
I also took off my starter so I could move and see things better under, around and between the carbs, air-intake/air silencer cover and starter. Three bolts to take off the starter so, again, not a big deal.
In order,
1. Disconnected the battery to the engine.
2. Disconnected the starter from engine block.
3. Plugged the air pulse hose.
4. Connected the hose from the drain nipple to crank case
5. Disconnected the primer solenoid from engine block then connected hose from the manifold to primer solenoid, reconnected the primer to block.
6. Connected bottom carb to the top carb hose.
7. Installed the fuel pump here by taking off the middle brass plug (and promptly dropped it down in the engine case, rats) put the pump on with two stainless 10-24x 2" screws.
8. Put the hose from gas line, inside engine case, quick connection on and threaded the hose under the starter to the fuel pump, marked, cut and installed the hose on the fuel pump with the arrow.
9. Put the hose on the fuel manifold and threaded it to the fuel pump, marked, cut and installed the hose on the other fuel pump connection.
10. Reconnected the starter
11. Reattached the battery.
12. Mixed up some 50:1 gas/oil mix in the gas tank, pumped up the priming bulb.
13. Attached the ear muffs to the engine, turned on the water
14. Looked in boat and house for the boat keys for 5 min.
15. Came back outside and turned the water off:mad-new:
16. Went back in the house, looked for the key for another 15 min. Wife found it in 60 sec.
17. Re-primed the system.
18. Turned water back on.
19. Turned the key and Zooom!:laugh:
