Distributor install?
smithrock
'85 Mercruiser V6
I'm trying to re-install my distributor but I can only get it about 1/4" from mounting flush, I have the grove at the bottom lined up for the oil pump. I'm TDC, I haven't turned the motor since it was removed. Any ideas? If I try to turn the rotor, it's tight with no play.
maxxman04
Re: Distributor install?
i'd put money on it that it's just a hair off from the oil pump shaft. 1/32" is all it takes. sometimes takes a time or three SLIGHTLY turning pump shaft to get it to drop.
Don S
Or, you are one tooth off.
Don S
Lift the distributor back up and turn it to the next tooth.
maxxman04
generally, the distributor will drop in in any spot, as the teeth are the same. the only thing that stops it is the pump shaft not aligning with distributor.
diehard
use a long flat head screw driver and stick it down the distributer hole and turn the oil pump shaft just a little should drop in place ..or get to where you have it and turn the moter over for a split second and pump should fall wright in place
smithrock
OK, so defintely don't force it and don't try and turn the rotor while dropping it down?
smithrock
still can't get it to drop! Is it ok to turn the crank until it falls into place?
maxxman04
seriously not a good idea. if distributor drops in the wrong spot, timing will be off, you'll be pulling distributor again, and back to square one. if motor is TDC compression stroke, rotor is facing where it should, and it still won't drop, it seriously means the oil pump shaft is lining up. after 20+ years of motors, i'm telling you this is the problem. UNLESS this distributor is a new or different one other than stock. if this is the case, there is a chance it is the wrong one, wrong gear, wrong shaft.
itsonlymoney
If the distrubutors are the same you should be able to get it to drop down by either turning the crank or bumping the starter once. Be sure your lined up and you should fall right into place. If it does fall one out, reset it and it should fall right in.
smithrock
Same distributor, I'll try lining up the shaft again. It's almost seated, just needs about 1/4" or so to go. there is resistance on the rotor where it is now
maxxman04
distributor should start to drop in with rotor facing a bit behind where it should, but as the gear meshes with cam gear, rotor will turn slightly and either drop right into place if oil pump shaft is positioned right, or it will stop just short of dropping all the way if pump shaft is off. you might be able to raise up on distributor without pulling it all the way out, push it back in gently. sometimes this will move the pump shaft just enough to get distributor to drop. also, you may want to take a screwdrive and GENTLY push down on oil pump shaft, just to make sure it's seated right, and may have to turn shaft ever so slightly, little by little till it's positioned right. tedious, yes, but that's better than forcing, wrong shortcutting.
smithrock
Ok. I'll try that. thanks. I'll let you know.
smithrock
GOT IT!!! thanks! Just had to finesse it a little and move the crank just a very little, and it dropped into place!!!!
Now to adjust the valves:(
Jeepster04
We had something similar to this happen. Pulled the distributor to check the electronic ignition and when we went to put the distributor back in it wouldnt go in if we lined up the marks from when we took it out.
Once we got a screw driver long enough to reach the oil pump it took around 5 times of slightly turning it then trying it.
Make sure you have drop a screw driver thats too short down in that hole!!! :eek:
