DIYer VS. Rot - 1988 Chaparral SX 1900 Rebuild - With Pix
Woodonglass
Honorary Supreme Mariner
Re: DIYer VS. Rot - 1988 Chaparral SX 1900 Rebuild - With Pix
I don't use flapper discs. I use a backup pad and the resin coated discs. 24 grit from Harbor Freight.
Backup Pad and 5 discs under $15 bucks.
StevenT
Thanks WOG. What would the average DIY do without HF. I think I'm there twice a month.
StevenT
I'm still in the grinding process. Grind, grind, and grind some more. The guys in the Chaparral factory sure laid in a lot of glass with those chopper guns they used. Thanks to the guys recommending Full face respirators. I was using the 3m half face respirator. I purchased a 3m full face respirator this week and it's worth the money. $63.99 on Ebay with a pair of cartridges. I don't have to stop and clean my prescription glasses at all now. No fogging at all and better protection.
[h=1][/h]
Woodonglass
If you are doing a full Gut restore with all that grinding This ^^^^ IS the only respirator to use!!!! Being a Woodworker I have the luxury of the same DustCollection system and it is a great thing to have but not everyone can afford to buy one for their restore project. I wonder if they are at the Rental Stores??
StevenT
Update I spent the long weekend grinding. Praise The Lord the bottom hull is done. I know I'm gonna find places to touch up. I left the deck lip for measuring purposes. I'm ready to build and install my transom. Before and after pix below. Any tips and or advice greatly appreciated. :joyous:
[/IMG]
[/IMG]
[/IMG]
[/IMG]
ezmobee
Nice work on the tear out and clean up. Time to put 'er back together!
StevenT
"Houston We Have A Problem" I had a mishap with the grinder-operator error. How should I fix this? Pix below. I think that is a streak below the hole
[/IMG]
[/IMG]
Hole Location in bow
[/IMG]
dna8085
That wood looks rotten anyways. I have exact same design in my boat and all of the wood was water logged, so i removed. looked like a 2''x2'' cut at a 45 degree angle. I'm just going to put a stringer in its place on both sides. picture shown after removal (went from bow to stern and were 6 inch segments of wood)
GT1000000
The outermost strakes on my tub were made that way, seems like a strip of plywood, not very big dimensionally, was laid in the strakes and then covered over with cloth and resin...of course, they became hollow over the years as the wood rotted away...
In my case, I just ground away the upper layer of glass, re-filled the strakes with thick PB flush to level of the hull, and layered on new 1708 biaxial cloth...right or wrong, overkill or not, it "felt right"...:rolleyes:...BTW, I only ended up doing that to the outermost strakes, and partially to the next couple of inner strakes, but only until they joined up with the newly installed stringers that took care of filling all but those sections...
Here you can see more or less what I am talking about...
Where the red lines are, that's where I did the PB filler, same on the other side...
You might be able to get away with just leaving them hollow as they are and just make a simple repair over the hole...
Woodonglass
OH NO!!! The boat is TOTALLY Ruined!!! I'll have to come haul it off for you. Won't charge you a dime!!!:joyous:
Seriously, You are NOW officially a Boat Restorer!!! Kinda like getting Blood on your face when you kill your first Deer!!! Mix up some PB, fill it Lay some 1708 over it and "FUHGITABOUTIT"
StevenT
I made my transom pattern today! I also placed my order with US Composites Thursday. My order should be here end of next week. Any advise guys?
[/URL][/IMG]
GT1000000
Any advise guys?
The transom pattern looks good...
Best advice I can give you is this...
Start getting excited because you are only days away from beginning the put back phase of the restoration!:rockon::whoo::encouragement:
Decker83
Really good job on the grinding.. Transom pattern is looking good..
Now the real work begins..
Have fun..
glnbnz
When you go to mix your fiberglass resin use the metric system: 500ml = 5ml hardener at 1% 7.5ml at 1.5% 10ml at 2%, so much easier than trying to mix pints and quarts.
Get yourself some syringes for accurate hardener measuring totally worth it.
I have seen that most people use standard disposable rubber gloves when working with resin, but I used the heavier kitchen gloves. I was having a hard time messing around with disposable glove especially once my hands got sweaty. With the kitchen gloves I cleaned them after each use with acetone and hung them to dry on the inside between batches. I just found that this was easier for me.
Good luck and I am looking forward to seeing more of your progress.
StevenT
Finished cutting out the transom today.
Clamped the pattern down so it would not move.
[/URL]
[/URL]
dna8085
Looks great! I'm almost to that step as well. I decided to remove ALL wood from the hull (strakes and all) good thing because all the wood was totally soaked and crawling with termites! Again great progress and always enjoy viewing the updates!
... Where is Middletown, OH? I'm originally from Marion, OH. I'm in the Air Force stationed in Las Vegas now.
Woodonglass
Very nice work on the transom cut out. Let the Glassin Begin!!!!:D
StevenT
Middletown is in between Dayton and Cincinnati along Interstate 75. I worked a festival in Marion about 10 years ago. Nice festival the headline entertainment was Marty Stuart.
StevenT
I sawed out 3 of 4 stringers today. The two outside shorter stringers went well and fit nicely. Any suggestions on making this easier?
[/URL][/IMG]
