- Joined
- May 16, 2009
- 9,370
Re: DP290A removal of hinge Pins??????
You will need the service manual for this job and maybe a Volvo special tool or two to help aid the removal. Start on page 142,
Boatinfo - Volvo Penta AQ280, AQ290, DP-A, DP-C SternDrive Service Manual
Good luck.
That is a big job to remove the Ram's. Hopefully the transom has the cutouts so the pins have clearance to be removed. If not, the transom shield will need to be removed from the boat.How do you remove these rams from the transom shield?
Good luck.
