rickasbury
Master Chief Petty Officer
- Joined
- Jul 13, 2011
- 835
So, I'm getting close to getting back in the water after what a year and a half....I have the rebuilt transom assy ready to go back on and will bring the boat home I hope tomorrow and install that on Sunday. I had a leak through the seal on the gimbal ring. So, I'm going to install the transom assy and just the out drive and poke it back in the water to test and make sure the leak is 100% resolved before I put the motor in. In preparation for the final install of the motor and the Bravo III out drive....I did the bellows earlier this year and a coupler was replaced just prior to that. When I did the bellows, I did the gimbal bearing but had difficulty getting the out drive back on. I had the alignment tool and thought it was aligned OK until a friend came over to help....he said you had to "align" the bearing a bit which he dit working the alignment tool back and forth a bit until it slid in and then the outdrive went on- now that I have had the motor and transom out, no way it will line back up. Should my alignment now be 100% motor mount adjustment or a combo of :"aligning the bearing" and the motor, just was not clear on that....also, on the outdrive, where the front mount for the trim cylinder goes through that is a nylon piece that either allows the drive to go a little further down or in the other position, not as much down....what is it supposed to be on my out drive??
