Bob's Garage
- Joined
- Apr 10, 2008
- 590
Re: engine fumes in cuddy
Well, I still am unable to make out the pictures, too dark. However, I think you guy's have figured it out.
What I don't understand is why you are getting water in there. Especially from the bilge. I would not expect water from the bilge to be able to get that high up the bow slope. Unless there is a LOT of water and you don't indicate that is the problem.
How much water are you talking about? A wetting of the carpet, or standing water like a puddle?
Block off the hole, no harm done, and see if the wetting continues. If it does, the water is coming from somewhere else.
Remember, water flows down hill unless forced to act differently.
You are describing water that not only is moving up hill, but jumping across the gap between inner and outer hulls. Or else there is so much that it must seek relief by flowing out the hole. Seems so unlikely.
So plug the hole and see what happens.
Your boat is constructed of at least 3 sections:
The overhead of the compartment is the bottom (inside) of the top cap.As a result you have 4 other possible potential points of entry for water into the "forecastle" compartment;
Blocking the hole will permit further testing to find the problem area. And this is something only you can do.
Good luck.
- The outside hull
- The inner liner - made up of the sole (floor), and the sides and any walls between occupied areas. This inner liner can be made up of more than 1 piece.
- The top cap. This is the cabin roof, gunnels and transom top
- They are the screws holding the bow light
- The bow cleat,
- Both chocks.
- And then of course, there is the possibility of a bad hull/top cap joint.
Good luck.
